Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco 7965 text size change?
NicP270591
Hi all,
I have recently acquired two Cisco 7965 IP Phones, booting them up and placing them side by side, I noticed that the text size of the actual Soft Keys, system message, and extension number is different on each phone. One is large font, the other is smaller. They both work fine, and I believe they are both loaded with the same SCCP revision (SCCP45.9-3-1SR1-S). Has anyone noticed this behavior before, and is there any way to get them to the same size? Nearly insignificant I know, but as these phones will be placed side by side we'd prefer them to both have the larger font and look virtually identical, the larger size seems to help a little with employees who have difficulty seeing clearly.
I'm assuming the fix is to check revisions and then upgrade/downgrade firmware on the smaller text phone to get it back to larger size, but just wanted to confirm?
Nic.
Rajan
Hi Nic,
Unfortunately there is no way to change the font size on this model phones although 89xx/99xx has that. You could try matching the firmware on both phones to see whether that helps if both the phones have different firmware versions..
HTH,
Rajan
Please rate useful posts
