Cisco 7970 Phone Background Image has lines through it
Steve Davis
Hi everyone, I have an issue where the configured programmable buttons have a line going through the image and gray over the color as well. If I unconfigure the buttons the image is normal.  Any suggestions on where to change this so my line buttons don't cover the image?
thank you,
Steve
Steve Davis
Actually it is anywhere there is text configured on the screen. The company name configured on the bottom of the display causes a gray line across the screen as well.
No way to change that, that's expected to happen.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
