Beginner
Cisco 8811 Phone error
I'm running Cisco CallManager System version: 8.6.2.25900-8 on our envirment and we are in the process of deplying a Cisco 8811 phone.
Step i took
Install Device Pack
Reset TFTP services
configure the cisco 8811 ph however
getting error message
Telephone service is unavaliable
TFTP timeout
No trust list installed
6 REPLIES 6
Rising star
Is option 150 configured on
Is option 150 configured on your dhcp scope with the tftp server ip address?
If the deivce pack was installed to add the 8811 phones as a device type, a reboot of the call managers are required.
If the device pack was only upgrading firmware, no reboot is required.
Device pack should be installed on all servers, then do a cluster reboot.
Beginner
Optin 150 is correct cauz i
Optin 150 is correct cauz i see the correct TFTP server ip address on Alternat TFTP server
however i didn't install Device pack on all servers only on the pub and only restart TFTP services
to confirm
we need to install device pack on server
and restart the cluster ?
Rising star
Yes, install on all servers,
Yes, install on all servers, then reboot cluster.
Reboot pub first, once its up and running, then reboot the subscriber.
Highlighted
Beginner
I restart host machine pub
I restart host machine pub first and then sub tfpt server sec
still getting same resuult
tftp timeout
no trusted list install
Rising star
Which device pack was
Which device pack was installed?
tftp timeout sounds like its not talking to the tftp server.
Advisor
[+5] to cehill.you upload the
[+5] to cehill.
you upload the Device Pack 8.6(2)(26157-1) and same can be downloaded from below link
https://software.cisco.com/download/release.html?i=!y&mdfid=283782839&softwareid=282074299&release=8.6%25282.26144%2529&os=
This would upgrade the firmware for all other models deployed.
regds,
aman
Content for Community-Ad
August's Community Spotlight Awards
