1249
Highlighted
Cisco 8821 IP Phone Fast Track Setup in CME 11.6
Hello Everyone,
I am trying to get a Cisco 8821 IP Phone to register with a Cisco 2951 ISR running 15.6(3)M1, which gives me CME 11.6.
The Cisco 8821 can only be registered via Fast Track in CME as full support isn't currently in the platform. The problem I have is that whilst I can get the phone to download it's firmware, and retrieve it's SEP007686CEB212.cnf configuration file, it doesn't try to register with the platform.
The following is my configuration:
tftp-server flash:dtblob8821.HE-01-005.sbn
tftp-server flash:fbi8821.HE-01-008.sbn
tftp-server flash:kern8821.11-0-3-6.sbn
tftp-server flash:rootfs8821.11-0-3-6.sbn
tftp-server flash:sb28821.HE-01-019.sbn
tftp-server flash:sip8821.11-0-3-6.loads
tftp-server flash:vc48821.11-0-3-6.sbn
voice service voip
 ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
 allow-connections sip to sip
 sip
  registrar server expires max 1200 min 300
voice-class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
voice register pool-type 8821
xml-config maxNumCalls 2
xml-config busyTrigger 1
transport tcp
phoneload-support
num-lines 1
description Cisco IP Phone 8821
reference-pooltype 9971
voice register global
 mode cme
 source-address 192.168.1.1 port 5060
 max-dn 500
 max-pool 150
 load 8821 sip8821.11-0-3-6.loads
 authenticate register
 authenticate realm all
 timezone 22
 voicemail 8000
 tftp-path flash:
 auto-register
voice register dn  116
 number 7027
 pickup-group 8618
 name Production
 call-forward b2bua busy 8618
 call-forward b2bua noan 8618 timeout 45
voice register pool  3
 id mac 0076.86CE.B212
 type 8821
 number 1 dn 116
 dtmf-relay sip-notify
 session-transport tcp
 username 8821-3 password cisco
 voice-class codec 1
 no vad
 create profile
As far as I can see, the handset can get the generated configuration file and it takes the password set under the username/password section of it's config so it is taking some bits of the config. It doesn't ever set it's line though, that remains greyed out on the phone.
From the handset I can see it complain about not being able to download the locale file, but I'm hoping this isn't an issue.
Has anyone managed to get an 8821 registered on CME?
Cheers,
James
1 ACCEPTED SOLUTION
Highlighted
VIP Advisor
Hi James,
Can you add bind command under voice service voip > sip > bind.
Also, please share the output of 'debug ccsip message' to see what errors are taking place during registration.
2 REPLIES 2
Highlighted
VIP Advisor
Hi James,
Highlighted
Thanks Mohammed, you had the right idea. Turns out the loopback interface that the customer had bound the media and signalling to was non-routeable from the voice VLAN.
Rebound now to a valid interface and the handset has registered without issue. For some reason I can't see your comment to mark it as correct, but trust me you were right.
