Cisco 8831 not registering with CUCM 10.5 (Internal Phone Error)
shawn13872
Running CUCM 10.5,  and just purchased a 8831 phone. The keypad is stuck with the Cisco Logo and CUCM shows the following " Inactive Load Failure Reason Internal Phone Error"
 Any ideas on how to resolve this issue:
5 Replies 5
Deepak Mehta
New 8831 phones doesn't work with old firmware below 10.3 , you must have got a sticker on the phone box which says do not downgrade the firmware.
Try to force the load -SIP8831.10.3-ISR2-2 from phone config page and factory reset the phone.
refer the link which says :
Step 7   For phones that are running Firmware Release 9.3(3), perform the following steps.
  1. Select the file cmterm-8831-sip.9-3-3-TO-10-3-1-v2.cop.sgn, click the Download Now or Add to cart button, and follow the prompts.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8831/firmware/10-3-1-sr1/english/release-notes/CS38_BK_826679D6_00_8831-rns-10_3_1sr1.html
you can download the file from below link
https://tools.cisco.com/search/results/en/us/get#q=cmterm-8831-sip.10-3-1SR2-2.k3.cop.sgn&pr=enus&basepr=enus&prevq=&sort=rel&start=0&hits=10&qid=1&websessionid=EZfUi_i7_AqzJiR4RqstpNA&navexp=&navlist=&navsel=&navop=&to=&fr=&un=&aus=false&ec=0&pf=&
readme says
In order to upgrade from 9.3(3) version, intermediate firmware cmterm-8831-sip.9-3-3-TO-10-3-1-v2 should be firstly installed and upgraded.
http://www.cisco.com/web/software/282074288/129938/cmterm-8831-sip.10-3-1SR2-2-readme.html
regds,
aman
Deepak Rawat
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8831/firmware/10-3-1-sr2/english/release-notes/cs38_b_phone-8831-release-notes-1031sr2.html#reference_9856A09E6943096E2E4BFABA62D77E55
Deepak
darin.marais
Level 4
Level 4
Our system is 11.5.1.11900-26
do we still need to install cmterm-8831-sip.9-3-3-TO-10-3-1-v2.cop.sgn?
Hi Darin,
Yes, it still need to be installed as it is a phone intermediate firmware upgrade.
It has nothing to do with the CUCM version you are on.
Hitesh
