Cisco 8831 phone not getting registered with CUCME 11.6
I am trying to register 8831 phone with CUCME 11.6
Below is my config. But the phone is not getting registering. Any ideas !!!
voice register global
mode cme
source-address ******* port 5060
max-dn 100
max-pool 100
load 8831 sip8831.10-3-1-16.loads
tftp-path flash:
file text
create profile sync 148945114458225A
auto-register
voice register dn 1
session-server 1
number 2999
name Conference Room
label Conf Room
voice register pool 1
busy-trigger-per-button 1
id mac AC44.F212.C361
type 8831
number 1 dn 1
dtmf-relay sip-kpml
username conference password 12345
codec g711ulaw
no vad
5 Replies 5
chevymannie
Is your dhcp setup for option 150 to point to the IP of the CME router?
Yes it is setup correctly
Guys any suggestions for this!!!!
Did you no create the profile and then create the profile to get the config file made?  Did you run a debug tftp to see if the phone is grabbing the config files or if it is asking for something it can't find?
Please check if you have SIP Registrar enabled
sip
  bind control source-interface XXXX
  bind media source-interface  XXXX
  registrar server
sip-ua
 retry invite 2
 timers trying 150
Wilson Samuel
