Cisco 8841 phones freezing
foldingspace
Our cisco phones keep freezing around every 6 weeks, the phones we have are CP-8841-3PCC and they appear to be on the latest firmware as the software version is sip88xx.11-3-1MPP-697.loads
Has anyone else had this issue and does anyone know of a fix for this?
5 Replies 5
George Sotiropoulos
Could you please verify the platform that you use (CUCM or CME) and if this issue appears to other models, if any on your enviroment?
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Hi George,
Thank you for your reply, I am not sure how to identify the platform, any idea on how to do this please?
foldingspace
My question was mostly to identify the PBX platform you use (Cisco Call Manager or Cisco Call Manager Express) and if you are not the Administrator of this you may need to consult your IT Team.
Nevertheless, please can you also consider the option of upgrading your phones' firmware as described on this thread?
George
Ok I will give this go, many thanks
bijpraka
The 11.3.2 firmware is released. Can you check if you see the same problem on 11.3.2?
Thanks.
