05-16-2017 06:07 AM - edited 03-17-2019 10:20 AM
HI,
I have CUCM 10.5.2 cluster & need to deploy new Cisco 8845 phones (50 handsets) in a branch site. What is the impact , if i deploy phones over the WAN , phones will get config/firmware? will it impact heavily on WAN link (4M link)?
Do i need to configure all phones at HQ & register with UCM prior to ship to branch ( to minimize the WAN utilization)?
Please advise .
Solved! Go to Solution.
05-16-2017 06:29 AM
Hi Suchi,
In that case, 50 phones registering over wan wont be an issue. You could directly connect it on the branch sites. If the firmware on those phones need to be upgraded, then you could also use the below procedure if you are worried about consuming wan bandwidth.
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200615-Cisco-IP-Phone-Feature-Peer-Firmware-S.html
Rajan
Pls rate all useful posts
05-16-2017 06:42 AM
Hi Such,
For bandwidth requirements see below, search for "Bandwidth Allocation Guidelines" in below link
http://www.cisco.com/c/en/us/td/docs/solutions/CVD/Collaboration/enterprise/11x/collbcvd/bwmgmt.pdf
Qes => Do i need to configure all phones at HQ & register with UCM prior to ship to branch ( to minimize the WAN utilization)?
Ans) Simple answer to that question is as long as there is ip connectivity between CUCM and I phone you dont have to configure them locally. Example if you have VPN tunnel between site that allows the required protocol \ ports the phone would register just fine.
For port usage see below.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/port/9_1_1/CUCM_BK_T2CA6EDE_00_tcp-port-usage-guide-91/CUCM_BK_T2CA6EDE_00_tcp-port-usage-guide-91_chapter_01.html
From (Sender) |
To (Listener) |
Destination Port |
Purpose |
Phone |
Unified Communications Manager (TFTP) |
69, then Ephemeral / UDP |
Trivial File Transfer Protocol (TFTP) used to download firmware and configuration files |
Phone |
Unified Communications Manager |
8080 / TCP |
Phone URLs for XML applications, authentication, directories, services, etc. You can configure these ports on a per-service basis. |
Phone |
2000 / TCP |
Skinny Client Control Protocol (SCCP) |
Phone |
2443 / TCP |
Secure Skinny Client Control Protocol (SCCPS) |
Phone |
2445 / TCP |
Provide trust verification service to endpoints. |
Phone |
Unified Communications Manager (CAPF) |
3804 / TCP |
Certificate Authority Proxy Function (CAPF) listening port for issuing Locally Significant Certificates (LSCs) to IP phones |
Phone |
5060 / TCP and UDP |
Session Initiation Protocol (SIP) phone |
Phone |
Phone |
5061 TCP and UDP |
Secure Session Initiation Protocol (SIPS) phone |
Phone |
Phone |
6970 TCP |
HTTP-based download of firmware and configuration files | ||
IP VMS |
Phone |
16384 - 32767 / UDP |
Real-Time Protocol (RTP), Secure Real-Time Protocol (SRTP)
Phone |
IP VMS |
(Rate if it helps)
JB
05-16-2017 06:13 AM
Is the CUCM configured with a public IP ?
I guess not. You need something like anyconnect VPN or expressway servers to connect and register with CUCM on the main site.
Rajan
05-16-2017 06:16 AM
Hi Rajan,
This WAN link is 4M MPLS connection & phones have direct connectivity to UCM
05-16-2017 06:29 AM
Hi Suchi,
Rajan
05-16-2017 06:42 AM
Hi Such,
From (Sender) |
To (Listener) |
Destination Port |
Purpose |
Phone |
Phone |
8080 / TCP |
Phone |
2000 / TCP |
Phone |
2443 / TCP |
Phone |
2445 / TCP |
Phone |
3804 / TCP |
Phone |
Phone |
Phone |
5061 TCP and UDP |
Phone |
Phone |
6970 TCP |
IP VMS |
Phone |
Phone |
IP VMS |
(Rate if it helps)
JB
