03-16-2016 11:43 PM - edited 03-17-2019 06:16 AM
Hello
I am planing to buy Cisco 8851 or 8861 IP phones.
Can i use these phones with 3CX or any other VoIP provider? I do not have Cisco unified system.
If i can use then do i need to change any firmware or it is ready to use same as Cisco 525G.
Thanx
Sanket
03-17-2016 01:09 PM
Yes, this is very do-able.
Go HERE. I've attached a known working SEPmacaddress.cnf.xml for a working 8861 that is using an Asterisk as the call server.
03-28-2017 10:48 PM
Hi Leo
It has been a long since i posted this question.
Finally i got Cisco 8865.
I went to the link which you send me in above post. But i think it was for older series (8900/6900).
My model is newer series 8800. I read somewhere that this new series is ready to use with third party call control (like 3cx?).
But when i plugged in the phone into network, i do not see any option to set it up with 3cx.
On screen it just ask for some QR code scan option.
Pls help me how to resolve this.
Sanket
03-28-2017 11:43 PM
The configuration is valid for Cisco phones running SIP. Try it.
03-29-2017 12:35 AM
Thanks for your time Leo.
I did uploaded SEP94D4690BC4ED.cnf.xml to TFTP server.
Two things:
Phone is working - Can make call and receive but No voice at any side.
Both party cannot hear voice at all.
and:
following is the log from TFTP
[03/29/17 12:47:17] 'CTLSEP94D4690BC4ED.tlv' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:17] >> 1: File not found
[03/29/17 12:47:18] 'ITLSEP94D4690BC4ED.tlv' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:18] >> 1: File not found
[03/29/17 12:47:19] 'ITLFile.tlv' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:19] >> 1: File not found
[03/29/17 12:47:20] 'SEP94D4690BC4ED.cnf.xml' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:20] Transfer of 'SEP94D4690BC4ED.cnf.xml' has successfully completed
[03/29/17 12:47:28] '/sl-bev-sip.jar' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:28] >> 1: File not found
[03/29/17 12:47:29] 'SIP45.8-4-2S.loads' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:29] >> 1: File not found
[03/29/17 12:47:38] '/g3-tones.xml' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:38] >> 1: File not found
[03/29/17 12:47:39] 'dialplan.xml' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:39] >> 1: File not found
[03/29/17 12:47:40] 'AppDialRules.xml' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:40] >> 1: File not found
I have following files in TFTP folder:
sip88xx.10-4-1SR2-85-3PCC.loads
sb288xx.10-4-1SR2-85-3PCC.sbn
vc488xx.10-4-1SR2-85-3PCC.sbn
fbi88xx.10-4-1SR2-85-3PCC.sbn
kern88xx.10-4-1SR2-85-3PCC.sbn
rootfs88xx.10-4-1SR2-85-3PCC.sbn
03-29-2017 12:46 AM
That's not a phone configuration problem. No voice is a NAT problem with the router.
03-29-2017 12:48 AM
It is in LAN.
Layer 2 and no VLAN no router. Simple network.
03-29-2017 01:07 AM
Draw your network.
03-29-2017 01:41 AM
Ok, now its working.
I did reset extension on 3cx.
But Expansion module is not working. It says disabled by administrator.
How can i resolve this?
And is it possible to configure this phone from webpage? Like Cisco 525G.
03-29-2017 01:44 AM
No.
03-29-2017 02:33 AM
And what about expansion module not working.
03-29-2017 02:49 AM
1. The KEM is not working because the configuration file doesn't specify the KEM.
2. The priority right now is to get the phone to work.
03-29-2017 03:18 AM
As said before Phone is working now.
Two things i am not able to do:
1. Expansion module is not working
2. Cannot upgrade firmware (to sip88xx.10-4-1SR2-85-3PCC)
First one is priority.
03-29-2017 04:52 AM
for Key Expansion Module i added following:
<addOnModules>
<addOnModule idx="1">
<deviceType>BEKEM</deviceType>
<deviceLine>36</deviceLine>
</addOnModule>
</addOnModules>
KEM is on now. But now i do i setup dial numbers for each key ?
Please help Leo.
