6438
sanketgroup
Beginner
CISCO 8851/8861 with 3CX or other VoIP provider
Hello
I am planing to buy Cisco 8851 or 8861 IP phones.
Can i use these phones with 3CX or any other VoIP provider? I do not have Cisco unified system.
If i can use then do i need to change any firmware or it is ready to use same as Cisco 525G.
Thanx
Sanket
13 REPLIES 13
Leo Laohoo
VIP Community Legend
Yes, this is very do-able.
Go HERE.  I've attached a known working SEPmacaddress.cnf.xml for a working 8861 that is using an Asterisk as the call server.
Hi Leo
It has been a long since i posted this question.
Finally i got Cisco 8865.
I went to the link which you send me in above post. But i think it was for older series (8900/6900).
My model is newer series 8800. I read somewhere that this new series is ready to use with third party call control (like 3cx?).
But when i plugged in the phone into network, i do not see any option to set it up with 3cx.
On screen it just ask for some QR code scan option.
Pls help me how to resolve this.
Sanket
Leo Laohoo
The configuration is valid for Cisco phones running SIP.  Try it.
Thanks for your time Leo.
I did uploaded SEP94D4690BC4ED.cnf.xml to TFTP server.
Two things:
Phone is working - Can make call and receive but No voice at any side.
Both party cannot hear voice at all.
and:
following is the log from TFTP
[03/29/17 12:47:17] 'CTLSEP94D4690BC4ED.tlv' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:17] >> 1: File not found
[03/29/17 12:47:18] 'ITLSEP94D4690BC4ED.tlv' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:18] >> 1: File not found
[03/29/17 12:47:19] 'ITLFile.tlv' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:19] >> 1: File not found
[03/29/17 12:47:20] 'SEP94D4690BC4ED.cnf.xml' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:20] Transfer of 'SEP94D4690BC4ED.cnf.xml' has successfully completed
[03/29/17 12:47:28] '/sl-bev-sip.jar' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:28] >> 1: File not found
[03/29/17 12:47:29] 'SIP45.8-4-2S.loads' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:29] >> 1: File not found
[03/29/17 12:47:38] '/g3-tones.xml' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:38] >> 1: File not found
[03/29/17 12:47:39] 'dialplan.xml' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:39] >> 1: File not found
[03/29/17 12:47:40] 'AppDialRules.xml' of type 'octet' is requested from 192.168.3.159
[03/29/17 12:47:40] >> 1: File not found
I have following files in TFTP folder:
sip88xx.10-4-1SR2-85-3PCC.loads
sb288xx.10-4-1SR2-85-3PCC.sbn
vc488xx.10-4-1SR2-85-3PCC.sbn
fbi88xx.10-4-1SR2-85-3PCC.sbn
kern88xx.10-4-1SR2-85-3PCC.sbn
rootfs88xx.10-4-1SR2-85-3PCC.sbn
Leo Laohoo
That's not a phone configuration problem.  No voice is a NAT problem with the router.
It is in LAN.
Layer 2 and no VLAN no router. Simple network.
Leo Laohoo
Draw your network.
Ok, now its working.
I did reset extension on 3cx.
But Expansion module is not working. It says disabled by administrator.
How can i resolve this?
And is it possible to configure this phone from webpage? Like Cisco 525G.
Leo Laohoo
No.
And what about expansion module not working.
Leo Laohoo
1.  The KEM is not working because the configuration file doesn't specify the KEM.
2.  The priority right now is to get the phone to work.
As said before Phone is working now.
Two things i am not able to do:
1. Expansion module is not working
2. Cannot upgrade firmware (to sip88xx.10-4-1SR2-85-3PCC)
First one is priority.
for Key Expansion Module i added following:
<addOnModules>
<addOnModule idx="1">
<deviceType>BEKEM</deviceType>
<deviceLine>36</deviceLine>
</addOnModule>
</addOnModules>
KEM is on now. But now i do i setup dial numbers for each key ?
Please help Leo.
Create
Recognize Your Peers
Content for Community-Ad
