269
Highlighted
Explorer
Cisco 8851 and Sennheiser Officerunner
I am trying to setup a Sennheiser officerunner headset to my 8851 phone. I am using the USB input and the phone is recognizing the headset but audio and the electronic hook-switch is not working. Any suggestions? I do have the recommended USB cable from Sennheiser and also have enable hook-switch control and wideband headset is enabled as well.
2 REPLIES 2
Highlighted
Hall of Fame Cisco Employee
Just to make sure, you're using the cable mentioned here:
http://sennheiser-headset-compability.herokuapp.com/
Have you tried different FW versions? or other device model? Or your laptop using Jabber or some other app?
java
if this helps, please rate
Highlighted
Hi Jaime,
Yes, I am using the cable suggested. This headset did work on a 7945 and 7965 phone in the past. When you say firmware versions do you mean phone firmware or headset?
Content for Community-Ad
