Cisco 8851 VPN
LSA4
Level 2
Level 2
I have a ISR4321-v router in the office working as my PBX all the 8851's in the office work fine.
Now i have another 8851 phone at home connected to my home lab, i would like to know is there a way to connect my 8851 at home to the CME at the office, i have client VPN setup(Meraki) for my laptop and it work 100%
I Hope the above makes sense, looking forward to hearing from you
Chris Deren
Here is what is supported for Remote Phone VPN access with CME along with required configuration:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmevpn.html
Vaijanath Sonvane
In Communications Manager Express 8.6 and later versions, Cisco Unified SCCP IP phones such as 7945, 7965, and 7975 located outside of the corporate network are able to register to Cisco Unified CME through an SSL VPN connection. I do not see any reference of Cisco 8800 Phones with CME through SSL VPN connection.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmeroad.html
For  remote phones, you can go through the "Remote Teleworker Phones" section in below guide:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmebasic.html#concept_AB93480DBF7A49808227EC99B80C9F73
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
