2491
Highlighted
Cisco 8861 Phone button for Speeddial
Cisco 8861 Phones has 10 buttons (5 on left hand side and 5 on right) my understanding is left hand side are only use for Line, Speed-Dial and right hand side for call pickup missed call check etc. is this possible i can use only 1 for line which is on left hand and rest 4 on left and 5 on right i can use for Speed dial?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Highlighted
Yes thats possible with
Yes thats possible with Enhance line mode feature. Check below link for more details
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/firmware/releasenotes/p881_b_cisco-ip-phone-8800-series.html#reference_C0581B37033CCE5B7DB882BC338DC886
Mohammed Noor
6 REPLIES 6
Highlighted
Mohammed Noor
Highlighted
Thanks for your answer, that
Thanks for your answer, that is good but i believe i need to upgrade my CUCM to 11.5 currently i am using 11.0.1 is this true? because i am not able to make any changes on right hand side button or do i need latest device pack? please advise
Highlighted
It would be supported with
It would be supported with your CUCM version, with a QED, check the link below.
https://ciscocollab.wordpress.com/2016/06/14/8800-series-11-51-firmware-enhanced-line-mode/
JB
Highlighted
Also
Also
Enhanced Line Mode
The buttons on the left and right of the phone screen can be set up as line buttons, giving up to five more line keys. Users see an alert for an incoming call.
Enhanced line mode is supported on Cisco Unified Communications Manager 9.1(2), 10.5(2), and 11.0(1) and any higher releases that are generally available. The latest Device Package is required. You can set the line mode in the Product Specific Configuration Layout portion of the Device Configuration window in Cisco Unified Communications Manager.
Enhanced line mode supports most but not all features with Firmware Release 11.5(1). Enabling a feature does not imply support. Read the following table to confirm that a feature is supported.
Table 2 Feature Support and Enhanced Line Mode with Firmware Release 11.5(1)
Feature
Supported by Firmware Release 11.5(1)
Notes
Answer
Yes
Automatically Answer Calls
Yes
Barge/cBarge
Yes
Bluetooth Smartphone integration
Not supported by Firmware Release 11.5(1)
This feature is being considered for future releases.
Bluetooth USB Headsets
Yes
Call Back
Yes
Call Chaperone
Call Forward All
Yes
Call Park
Call Park Line Status
Call Pickup
Yes
Call Pickup Line Status
Yes
CFWA on multiple calls
Cisco Extension Mobility Cross Cluster
Cisco IP Manager Assistant (IPMA)
Cisco Unified Communications Manager Express
Conference
Yes
Computer Telephony Integration (CTI) applications
Yes
Decline
Yes
Device Invoked Recording
Directed Park BLF
Do Not Disturb
Yes
Enhanced SRST
Extension Mobility
Yes
Group Pickup
Hold
Yes
Hunt Groups
Incoming Call Alert with configurable timer
Intercom
Yes
Key Expansion Module
Malicious Call Identification (MCID)
Yes
Meet Me
Yes
Mobile Connect
Yes
Multilevel Precedence and Preemption
Mute
Yes
Programmable Line Key (PLK) Support for Queue Status
Yes
Privacy
Yes
Queue Status
Yes
Quality Reporting Tool (QRT)
Yes
Right to Left locale support
Redial
Yes
Silent Monitoring and Recording
Speed Dial
Yes
Survivable Remote Site Telephony (SRST)
Yes
Transfer
Yes
Uniform Resource Identifier (URI) Dialing
Yes
Video Calls
Yes
Visual Voicemail
Yes
Voicemail
Yes
JB
Highlighted
I installed new Firmware also
I installed new Firmware also new device pack but I am still not able to allocate SD on right hand side.  any idea ?
Highlighted
Hi Firasat,
Hi Firasat,
From DE discussion i see the feature was documented on July 26th, 2016, in CCO i see the last DP posted on 11-JUL-2016, i would recommend to open a TAC case so that an engineer can reach BU to get the exact date when DP would be available.
JB
