cisco 8861 with cme 10.5
alap84
Hello All
we recently purchased few 8861 sip phones, i confugured that with cme through fast track, problem is i am unable to see corporate directory when pressing contacts button. other phones like 78xx and 39xx showing proper,
any idea or hint which can help
Brandon Pierce
Level 4
Level 4
Two things off the top of my head, a search will reveal more for you:
  1. no create cnf-files / create cnf-files then reboot the phones
  2. The phone type is set to 8861 on the CME correct?
Make sure the .cnf.xml files are there after you re-create the files and reboot the phones.  If they arn't, then your phone isn't pulling it's configuration.  You might need to debug the tftp and watch it request the file for more help.
bro
this is sip phone not sccp phone,
in sip phones profile is created in
voice register global
 create profile
the meaning of "fast track"  there is no pre type defined to add phones, u have to create a pool for similar type
google will help u on this ;)
I made a basic mistake of misreading your post, there is no reason to demean or make statements that I don't understand something.  I saw a phone then saw "CME", I'm sorry for inconveniencing you, someone else can help if they want at this point.
dangquangminh
how about putting url directory command in voice register global mode
url directory http://.....
 mode  cme
 url directory http://192.9.200.83/dir/main.xml
- See more at: https://supportforums.cisco.com/discussion/12334311/it-possible-specify-different-url-directory-service-lobby-phone#sthash.3DcBPhJc.dpuf
 mode  cme
 ! - See more at: https://supportforums.cisco.com/discussion/12334311/it-possible-specify-different-url-directory-service-lobby-phone#sthash.3DcBPhJc.dpuf
 mode  cme
dangquangminh@vnpro.org CCIE#11897 6016 Tillsdows Dr, Mississauga,ON Canada L5N4M3
