3772
AlpBakir0524
Beginner
Cisco 8865 Activation
Hello
I bought Cisco 8865 IP Phone, and I have tried to use it.
But I can not use it because it shows me an activation screen.
Even I have entered my SIP server IP and user/password.
My IP Phone has been connected with Ethernet cable, but it's "Verify your service domain and internet connectivity and then try again"
How can I activate Cisco 8865? or there is a useful guide?
Also, where is a TFTP server?
Best regards
11 REPLIES 11
Leo Laohoo
VIP Community Legend
Thank you for your reply.
But I am not sure that how I can get 16-digit activation code in the form xxxx-xxxx-xxxx-xxxx?
Get someone who knows how to setup DHCP Option 150.
Jaime Valencia
Hall of Fame Cisco Employee
You bought a device with enterprise FW, refer to any of the posts on CSC on how to configure your device with the xml files, Or get a 3PCC device with a config GUI.
Your phone is trying to register to either the Cisco cloud services or via MRA because the TFTP server is unreachable.
java
if this helps, please rate
Already I know about that, I want to know how can I get a 16 digit activation code? from where?
Jaime Valencia
I have tried it.
Once I add new Device for a user, it's say
This user cannot activate Cisco IP Phones. To be able to do this, you must enable Webex Calling for them from the Users page.
I go to a user panel, and How can I enable Webex Calling?
However, I got a 16-digit activation code and scan the QR Code, so I got success.
But I can not move to the next screen, it just shows me "Phone is registering".
When I see the log, it says, "Token refresh failure"
Thank you
Jaime Valencia
Plenty of info if you google enable webex calling
https://help.webex.com/en-us/njvdjf2/Configure-Cisco-Webex-Calling-for-Your-Organization
https://help.webex.com/en-us/8jda92/Cisco-Webex-Calling
I'd strongly suggest you reach out to your SE and discuss training options for the webex control hub if you're going to be the one in charge.
java
PS : I bought Cisco 8865 IP Phone from Amazon
Thank you for your help However, how can I convert from Enterprise to MPP FW? Activation success, but IP Phone won't allow registering.
I have charged with the Starter membership. I got a license for 1 user.
When I tried to add a new Device, it says.
"This user cannot activate Cisco IP Phones. To be able to do this, you must enable Webex Calling for them from the Users page."
As I know, I should see the screen to select IP Phone device, and add Phone Number, Extension
Am I wrong? What is my next step?
Thank you
Did you ever get an answer for this?
Create
Recognize Your Peers
Content for Community-Ad
