Cisco 8865 Wireless Connect
We have a customer who wants to place Cisco 8865 in the user cubicals, without plugging them to LAN. And user Laptop should be connected to phone via ethernet.
Cisco 8865 can connect to WLAN and perform phone functions, but we need to know if a PC plugged into PC port of the phone, what will happen. Will the PC get network connectivity ?
And can we use two VLANs for voice and data as we do in LAN connection?
We cannot simulate this since we currently have no access to Cisco 8865 in office environment.
Appreciate your support.
Jaime Valencia
No, that's not how it works, if you enable WLAN and use the phone that way, the ethernet ports in the back are disabled, you cannot piggyback onto the wireless connection from the phone for other devices using the ethernet ports.
java
if this helps, please rate
