Cisco 8945: change text of softkey button
Maxime Peccoux
Hello everybody,
We have a lot of complaint about some softkeys text label translation.
Is there a way to custom softkey text label ?
Thank you
Best regards
CUCM: 9.1.2.12900-11
FW 8945: SIP894x.9-4-1SR1-1
2 Accepted Solutions
Sreekanth Narayanan
Do you mean you want to change the name of the softkey? For e.g., instead of NewCall -> New. Is this what you want to achieve? This cannot be done.
The softkey names that have come with the phone locale are static.
Chris Deren
Unfortunately no, the soft key names are defined within the code.  If you see that they are translated incorrectly you can open a TAC case and a bug can be created to address it in future releases.
Chris
Sreekanth Narayanan
Yes, some softkeys name are not very well translated in French. So it's not possible to change them :(
I will open a TAC to correct them
Thank you
Chris Deren
Chris
