cisco 8945 ip phone issues
Rohit Mangotra
Beginner
Beginner
I have got CUCM 8.6.2 (Pub and Sub). In my environment I have 7911,7940,7945.......uptp 7965 series ip phone working fine no problem at all. We just got 8945 ip phone and I connected them to the network and they are registered to publisher. I can call internally, can recieve calls internally and externally however, I am not able to call externally. When ever I try to dial external number prefix ''0'' to get outside line and then the outside number it gives busy tone. Can anyone plese help me in this. Thanks.
16 Replies 16
Aman Soi
Advisor
Advisor
Hi Rohit,
Are 79XX phones able to call outside[ PSTN ]?
Secondly,are the 79XX and 8945 ip phone in same partition and CSS?
Is the call hitting the gateway after u dial from 8945 IP phone?
regds,
aman
Hi Aman,
yes all 79XX series phones are able to call outside. Both of them are in same partition and css. I checked the voice gateway with sh isdn history and i can not see any call that is hitting from 8945. However, I made external call from other phone 7965 and I can see that over there. If I call from outside to 8945 phone I can see that call in the gateway. Thanks.
Rohit
Hi Rohit,
can u run debug isdn q931 on VG and check if the call is hitting from 8945 to outside PSTN? Please capture the logs .If the call is hitting VG, please share the called number as well.
Is your VG on MGCP or H.323 ?
Are u able to dial complete PSTN number after u press "0" on 8945?
regds,
aman
Hi Aman,
My VG is on H.323. I am able to dial complete pstn number after pressing ''0'' on 8945.
Rohit
Hi Aman,
Its strange that I can not see any calls on the voice gateway after debug isdn q931 is on. But I can make external calls from other phones just fine. Can not see nything in router. I think VG router needs a reboot. What do u think?
Rohit.
Hi Rohit,
Are u telneting  into the router or connected through Console ?
If through Telnet , then, are u using terminal monitor and check again for the debugs.
Do not reboot the router.
regds,
aman
Hi Aman,
I can see the logs now I enabled the terminal monitor and then it started working. I am getting this error
Apr 26 06:05:31.622: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
Apr 26 06:05:31.622:  Use file-acct reset when the problem is recovered
Apr 26 14:05:31: %ISDN-6-DISCONNECT: Interface Serial0/0/0:29  disconnected from 93972784 , call lasted 23 seconds
Apr 26 06:05:31.698: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
Apr 26 06:05:31.698:  Use file-acct reset when the problem is recovered
Apr 26 14:05:33: %ISDN-6-CONNECT: Interface Serial0/0/0:18 is now connected to 894613866 N/A
Apr 26 06:05:35.818: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
Apr 26 06:05:35.818:  Use file-acct reset when the problem is recovered
Apr 26 06:05:35.834: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
Apr 26 06:05:35.834:  Use file-acct reset when the problem is recovered
Apr 26 14:05:37: %ISDN-6-CONNECT: Interface Serial0/0/0:6 is now connected to 418952567 N/A
Apr 26 06:05:46.214: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
Apr 26 06:05:46.214:  Use file-acct reset when the problem is recovered
Any ideas??
Rohit
Hi Rohit,
I can see some numbers like 93972784[call lasted for 23 seconds],418952567,894613866 .
What u do is try making a call from outside to 8945 IP phone and then,try outside call from 8945?
Just make a note of the called/calling numbers and then, share the log.
regds,
aman
Hi Aman,
These are the logs that we need.
**From mobile to 8945 ip phone (External to Internal call)
Apr 26 06:31:01.190: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x00D9
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18386
                Preferred, Channel 6
        Calling Party Number i = 0x2181, '425494100 //mobile number'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '93640881 //8945 ip phone number
                Plan:ISDN, Type:Subscriber(local)
        High Layer Compat i = 0x9181
Apr 26 06:31:01.214: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x80D9
        Channel ID i = 0xA98386
                Exclusive, Channel 6
Apr 26 06:31:01.334: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x80D9
        Progress Ind i = 0x8188 - In-band info or appropriate now available
Apr 26 14:31:05: %ISDN-6-CONNECT: Interface Serial0/0/0:5 is now connected to 425494100 N/A
Apr 26 06:31:07.270: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x00D9
**From 8945 ip phone to Mobile (Internal to External call)
Apr 26 06:38:31.674: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 0893640881
Apr 26 06:38:31.674: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x2DDA callID = 0xAD5B switch = primary-net5
interface = User
Apr 26 06:38:31.674: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x2DDA
        Bearer Capability i = 0x8890
                Standard = CCITT
                Transfer Capability = Unrestricted Digital
        Channel ID i = 0xA9839D
                Exclusive, Channel 29
        Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0081, '0893640881'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0425494100 // Mobile number'
Apr 26 06:38:31.722: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xADDA
Apr 26 06:38:34.678: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xADDA
        Cause i = 0x80D8 - Incompatible destination
Apr 26 06:38:34.682: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x2DDA
Apr 26 06:38:34.710: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xADDA
Apr 26 06:38:34.718: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
Apr 26 06:38:34.718:  Use file-acct reset when the problem is recovered
Apr 26 06:38:34.734: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlie attempt
Apr 26 06:38:34.734:  Use file-acct reset when the problem is recovered
Hi Rohit,
I think u are using Video on 8945 IP phone while on other 79XX phones u are not using Video .Is that Correct?
Do u get option of entering command bearer-cap speech under the voice-port?
regds,
aman
Hi Aman,
Yes we are using video internally when calling from one 8945 to another. otherwise its only voice.Yes I can enter this command under voice-port 0/0/0:15
rohit
Hi Rohit,
From the logs for outgoing calls, it shows Incompatible destination and there is an issue related to this while Video is used.
Please enter the command and check for results for all incoming and outgoing calls for all models.
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080093f62.shtml
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080569b65.shtml
regds,
aman
Hi Aman,
It worked. I disabled the video from the phone first and tried to call out it worked. Then I entered the command in the voice-port and enabled the video as well. It worked with that and all the other phones are also working fine. Thanks a lot man for your help and patience. I you don't mind was it from this section 0x80D8 - Incompatible destination
that you came to know what the issue was? Once again thanks a lot.
regards
Rohit.
