Cisco 8961 , not registered ( rejected )
hugomdbaez
Hello to all ,
I have CUCM 8.6.2.22900-9 and a particular case :
A Cisco 8961 is not registered , the message in the CUCM is rejected , and in the phone{s display is Phone not registered .
I have test in a lot of ways ( shut and no sht of the sw port , factory default to the phone , Static IP address ) and nothing works .
Can anybody help me ?
Thanks and best regards
Hugo
8 Replies 8
Chris Deren
Is phone defined in CUCM or are you using auto registration?
What is the status messages log show on the phone?
Did you delete all certs from phone?
Chris
Chris :
The phone is defined in CUCM .
The messages are :
VPN not configurated
VPN error
MAC.cnf.xml.cgn ( http )
Trusted list updated
updating trusted list
and a loop of this ..........
How can I delete the certs of the phone ??
many thanks
Hugo
Its registered !!!
THIS MODEL never is registered without a directory number .
Thanks Chris and ALL
Hugo
Great Hugo, so nothing changed and it just started to work?
HTH, please rate all useful posts!
Chris
Chris , I  add a directory number and the phone was registered inmediatly
Hallo how do additional a directory Number only with command line?
For CUCM, you don't create Directory Numbers (DNs) via the command line, only the GUI.
Or do you have CUCME (CUCM Express)?
Maren
I have only cme created with command line
