Cisco 9971 and BLF for call lists
raziel78kain
Level 2
Level 2
does Cisco 9971 support BLF for call lists?
It supports correctly BLF speed dials, but it seems it doesn't works with call lists, corporate directory, ...
Regards.
clileikis
Level 7
Level 7
Hi there,
According to the 9900 Admin guide, it is supported:
Presence-enabled directories
Allows a user to monitor the call state of another directory number (DN) listed in call logs, speed-dials, and corporate directories. The Busy Lamp Field (BLF) for the DN displays the call state.
For more information, go to the "Presence" chapter in the Cisco Unified Communications Manager Features and Services Guide.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cuipph/9971_9951_8961/8_5/english/admin_guide/9971usr.html
HTH,
Chris
I have configured just configured the Presence, and with other phones (7900 series, IP Communicator) it works.
But all the phones where it works are SCCP, while 9971s are SIP; are there particular things to configure/check with 9971, or SIP phones in general?
Remember that BLF speed dials on 9971s work; only BLF on call lists or directrories doesn't work.
Regards.
