03-28-2012 06:17 AM - edited 03-16-2019 10:20 AM
Hi there,
I've read that 9971s do not support PEAP, but it was a relatively old document. Is there a firmware that now supports PEAP? If not, does anyone know if it's on the horizon?
Josh
03-28-2012 06:22 AM
EAP-TLS and PEAP-GTC are on the "to do" list for the 9971, but haven't been committed to any release yet.
Ronak Patel
Please rate helpful posts.
03-28-2012 06:25 AM
Thanks Ronak!
03-28-2012 06:28 AM
You can rate this post by clicking the stars below the comments.
Ronak Patel
01-29-2014 01:27 PM
Do you know if PEAP was ever added to the 9971 firmware?
Zack
01-29-2014 10:55 PM
Hi Zack,
Please check the following link for cucm 10.0, it does not list PEAP.
Manish
02-13-2014 05:27 PM
...and despite that, the 792x phones have supported it for some time as does the new DX650.
Zack, I could find no evidence that support for PEAP has or will make it to the 9971's any time soon... it certainly isn't in the 9.3 firmware, and I don't see any mention of it in the 9.4 release notes either.
