Hi guys, does any one know if Cisco Jabber and Cisco AnyConnect are supported in the following devices:
- GALAXY Note 10.1 N8000 with Android Ice Cream Sandwich v4,0
- SAMSUNG SGH-I957 GALAXY TAB 8.9 LTE 3G with Android OS v3.2 (Panal)
I would appreciate your comments and experience.
Thanks a lot.
David
i am using galaxy note and i have any connect.
it worths to download it from the play store and give it a try
Anas
please rate if it is helpful
Sent from Cisco Technical Support Android App
Hi Anas, thanks a lot for your response.
Do you have installed Cisco Jabber also?
To intall Cisco AnyConnect, do you have to make you a "root" of the device?
I'm asking that 'cuase I'm planning to buy a couple of GALAXY Note 10.1 N8000 devices at least, and I wanna make sure about that.
Thanks again
David
