09-21-2011 11:52 PM - edited 03-16-2019 07:07 AM
HI,
I have two offices (connedted with each other) both offices are connected to CUCM via h323 gateway. One site is having E1 line and other is having limited FXO ports. I want to use Cisco ATA 187 on the site where i have FXO ports. But at the same i want that ATA to be connected with E1 line.
Can i put ATA on one site and use line and extension of the site where i have E1 line.
09-22-2011 04:23 AM
Can you supply more info,
Do you have a CUCM at site "A" and "B" with an intercluster trunk or are they CMEs ?
If they are the same cluster I do not see an issue with giving the ATA187 the same css etc as the native phones at the E1 site
Alex
09-22-2011 05:47 AM
CUCM is placed in third place. Both sites are connected with that CUCM via MPLS link.
04-23-2012 01:16 AM
Dear guys
I have another question in the same field
I have an IP network over VSAT
I am using the ATA187 to connect analog phones in the remote areas, and I have a call maneger server in the HUB station.
my question is,
if i have a PBX in one remote site ( support FXO interface), can I connect one ATA 187 on it ? and conseder it as normal analog phone or NOT ?
please advise
