Cisco ATA 190 Two Fax Numbers
moe2
Dears,
I have one Cisco ATA 190 device connected on my HP printer and
it's working fine .
now i'm trying to add ONE more FAX number to the same ATA 190
but it's not working !
is it possible to have 2 fax number working on one ATA 190 device or not ?
if yes kindly HOW !
2 Accepted Solutions
George Sotiropoulos
If you are using CUCM then you may check the following link on "Configuring the ATA 190":
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cata/190/1_0/english/administration/guide/sip/ATA190/a190_ag3conf.html
Please check the following:
Configuration
1. On the Cisco ATA 190 web page, go to Voice > Line 2 > Line Enable.
2. Choose yes to enable or no to disable.
3.
Click Submit. Wait for 40 seconds for the change to take effect.
Hope it helps,
G
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Flo.Matalis
This is possible. What is the status of your 2nd port in Call Manager? Make sure it is registered first.
Note ATA 190 has two FXS ports, and each port has its MAC address. The first ATA 190 port uses the MAC address and the second ATA 190 port uses the shifted MAC address (example, AABBCCDDEEFF to BBCCDDEEFF01). You can add two devices from the Unified CM administration page.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cata/190/1_0/english/administration/guide/sip/ATA190/a190_ag2str.html
George Sotiropoulos
Configuration
3.
Hope it helps,
G
Flo.Matalis
farispv
Dear ,
Could you please help me to clear below as am facing to setup FAX by using Cisco ATA 190.
the ATA Registered with CUCM
1. How you configured FAX with Cisco ATA, is your line SIP or PSTN line
2. Will it possible to have FAX Service over SIP ,
FARIS
