07-02-2020 08:07 AM
Good Day,
we bought our first Cisco ATA 191 but cannot configure it.
The device have an ip from the DHCP-Server.
After connecting to the web http://x.x.x.x we can login with admin/admin.
There is no option to configure anything. We have the tabs "Voice" "Administration" and "Status".
In the support portal i cannot find anything about this, just there should be a "Quick Setup Wizard" at the first time. This is missing here.
01-20-2021 01:29 PM
Did you figure this out? I'm having this problem too.
01-20-2021 10:52 PM - edited 01-20-2021 10:53 PM
What phone control system are you using with the ATA? CUCM or CME, or other non Cisco option?
01-21-2021 06:15 AM
We're using this with a non-Cisco PBX.
01-21-2021 06:53 AM - edited 01-21-2021 07:02 AM
With 3:rd party system you need to manually configure the XML file and get it onto the device for it to be configured. The device will use option 150 in DHCP to find the TFTP server where it requests to download the configuration file (XML).
04-29-2021 01:19 PM
Hi Roger! Hope you are doing fine. Hey, we have a customer escalation with this exact same scenario ( ATA191 + Non cisco PBX) Is there any way you can point us in the right direction to get our hands on that XML file? Any help would be appreciated. Thanks!
03-03-2023 11:26 PM
As you’re a Cisco employee you should have internal sources where you can get this information.
03-03-2023 04:15 PM
Hello Roger I am having this same Issue but i am using UCM Platform to use the ata191 any ideas what causes this issue besides the XML file?
03-03-2023 11:29 PM
With CM the ATA device should get all the configuration from the CM. Make sure that you have configured the ATA in CM under Phones and also make sure that you have option 150 pointed to the TFTP server in your CM cluster so that the ATA can fetch its configuration file.
08-02-2023 04:33 AM
I have pointed option 150 to the tftp server on my cm but it's still the same. Any idea's thanks J
08-02-2023 05:26 AM
Do you see that the ATA register in CM?
08-02-2023 05:29 AM
No, it's not registered
08-02-2023 07:23 AM - edited 08-02-2023 02:25 PM
Then you should troubleshoot that as without coming in contact with CM the ATA would not pickup the configuration to enable the web service.
