Cisco ATA 192 Multiplatform with CUCM 12 ?
passakorn.m
is the Cisco ATA192 supported on CUCM version 11 or 12 ?
i see the ATA192 Multiplatform datasheet mention that. it does not work with Cisco call control systems.
i need ATA with 2 port RJ45 which support on CUCM 11 or 12.
please help.
Rob Huffman
Hi there,
The supported ATA model for CUCM is the ATA 191;
https://www.cisco.com/c/en/us/products/collateral/unified-communications/ata-190-series-analog-telephone-adapters/datasheet-c78-739907.html
The ATA 191 is supported with CUCM 10.5.1 and later.
Cheers!
Rob
thank you, but if i need ATA with 2 ports RJ45. what model can work with CUCM ?
