Cisco ATA-192MPP SSH second login prompt?
George Spanos
I am testing an ATA-192MPP on firmware 11-1-0MPP0401-002 . I've found the SSH function which I have been hoping for at least 5-7 years. I am able to login via SSH but once I get in I receive a second set of login/password prompts that I can actually skip by hitting enter or typing ?.. is this a bug or is the second set or prompts meant for Cisco to login as "root" or otherwise?
When I get the DEBUG> prompt, I'm logged in...but then get a password prompt I can skip...after that it replies with the output of my "?" command.
Example
Router#ssh admin@10.1.81.146
Password:[PASSWORDHERE]
login: [PRESS ENTER TO SKIP]
DEBUG>?
Password:? [ENTER OR ? TO SKIP]
dial port <number> dn <phone number>
call answer port <number>
call end port <number>
end the current call on this port
call end port <number> all
end all calls on this port
call hold port <number>
call resume port <number>
call transfer port <number> initiate
call transfer port <number> complete
call conference port <number> complete
reboot
powercycle phone, please be careful to use it
reset soft
reset hard
reset factory
show call detail all
show call detail active port <number>
show call detail port <number>
show call summary all
show call summary port <number>
show call summary active port <number>
show phone-information
show port <number>
show port all
show stream summary
show stream summary audio
ipv6 config enable_with_autocfg
ipv6 config enable_without_autocfg
ipv6 config disable
ipv6 config autocfg_on
ipv6 config autocfg_off
dhcpv6_ready_logo_test_mode <0|1>
show ipv6
ping <ipv4>
ping6 <ipv6>
traceroute <ipv4>
traceroute6 <ipv6>
log_runtime set <1|0>
debug_log_save all |xml |fp on |off
mwi_solution show |set <int> (0: DSPG solution, 1: SLIC solution)
DEBUG>
0 Replies 0
