11-14-2017 06:58 AM - edited 03-17-2019 11:35 AM
Hi Guys
We have plan to upgrade CUCM from 9.1 to 11.5 and Cisco attendant console enterprise 9.1.x.
Please advise, which attendant console version is compatible CUCM 11.5?
11-14-2017 07:44 AM
I'd suggest you upgrade to Cisco Unified Attendant Console Advanced (Advanced replaced Enterprise) version 11.X which is backwards compatible with CUCM 9.X, this way you can upgrade CUAC ahead of time if you choose to.
11-20-2017 12:52 AM
Is there anything that need to backup and import to CUAC 11.0 from Enterprise Console Version 9.1.1.2223. ?
11-20-2017 05:02 AM
You need to follow the Attendant Console upgrade guide and release notes which lays out all details step by step.
11-20-2017 10:20 PM
Could you please share "upgrade to Attendant Console Version 11.0.2.10" document ?
11-21-2017 05:42 AM
11-22-2017 01:19 AM
Please advise, Unified Attendant Console Enterprise Edition Server 9.1.1.2223 is compatible CUCM 11.5?
11-22-2017 05:59 AM
No, you need to upgrade Attendant Console to be compatible with CUCM 11.5. You can do it either prior to CUCM upgrade or at the same time.
12-09-2017 11:14 PM
I have downloaded the file "CUACA_SV_11.0.2.10" for upgrade. Is this the file that use both for installation and upgrad ?
Also please advise, I am unable to see the CUAC upgrade option in PUT. What is the upgrade order procedure for CUAC?
12-10-2017 05:59 AM
Yes, the same file is used for upgrades and new installs.
if you don’t see the product on PUT tool you either don’t have current support on it or it’s under different contract.
11-14-2017 09:11 AM
The install/admin guide for each CUACA release outlines the CUCM compatibility, as well as the client/OS/CUCM compatibility, you need to review that documentation to find one that is suitable for your CUCM version, as well as the OS version you will have in the clients.
11-15-2017 11:49 AM
Ok..
Please advise, how to use licenses from attendant console 9.1.x to 11.x ?
11-15-2017 12:08 PM
You need to request upgrade through PUT tool (cisco.com/upgrade), you can also get temp license from cisco.com/go/ac.
