09-30-2016 02:13 AM - edited 03-17-2019 08:14 AM
Hi ,
I installed Cisco attendant console standard 10.6 on window 7 ( 64-bit ) and successfully registered with CUCM 10.5.x.
After that , login to Cisco attendant console and try to call to other IP phones. I can make the call and other IP phones is ringing but unable to hear anything from cisco attendant console.
so that I tried to call from other IP phone to cisco attendant console. I could see the incoming call but couldn't hear the ringing and I could even answer but still no sound.
I checked the PC sound card and drivers but all are working fine.
Could you advise on that issue to solve it.
Thank you!
Best Regards,
VT
09-30-2016 06:40 AM
AC is a client that controls a phone, not a soft phone, Are you answering the call from the IP phone you logged onto with AC?
09-30-2016 07:29 AM
Hi Chris,
Yes, I answered the call from IP phone and connection is established between AC and IP phone but could not hear anything in both sides.
Best Regards,
VT
09-30-2016 09:00 AM
What is you just make a phone call directly between the phones?
09-30-2016 10:13 AM
phone to phone is working fine.
The only problem is that no ringing sound in AC when incoming call arrived
Even though I answered the call, still no sound.
I checked the PC sound card and driver is also working fine.
Could you advise how to solve it.
10-03-2016 01:44 AM
Is there any additional file suppose to install like media file or Etc?
10-27-2016 01:52 PM
Vector5678,
Why are you checking your sound card?
When you use CUACS, the audio is delivered by the Cisco phone, if you don´t have any Cisco phone, try to use a Jabber client.
