235
Highlighted
Beginner
Cisco BE6K Solution Upgrade
Dear All,
We have two Cisco BE 6000 servers (C220M3). On which we have CUCM, IMP, and CUC. All are 10.5.x version. We need to upgrade the whole solutions:
1) Upgrade the existing ESXi5.5 to the Latest 6.7.
2) CUCM 10.5.X to 12.5.x
3) IMP 10.5.x to 12.5.x
4) CUC 10.5.x to 12.5.x
I have the following concerns:
1) Does Vmware Esxi 6.7 Supported on our BE 6000 servers (UCS C220 M3)
2) Can I upgrade the ESXi 5.5 to 6.7?
3) How can I get the license for ESXi once the upgrade is done?
2 ACCEPTED SOLUTIONS
Highlighted
Hall of Fame Cisco Employee
You need to review VMware's documentation for 1 and 2, the HCL and the upgrade matrix for ESXi.
java
if this helps, please rate
Highlighted
Collaborator
vmware 5.5 to 6.7 upgrade ís possible. check the compatibility matrix  from below link.
https://ucshcltool.cloudapps.cisco.com/public/
https://www.vmware.com/resources/compatibility/detail.php?deviceCategory=server&productid=20704
Screen Shot 2020-09-21 at 6.41.39 PM.pngScreen Shot 2020-09-21 at 6.41.46 PM.png
if you have valid  SWSS  follow below guide to get the ESXI  license from PUT.
https://www.cisco.com/c/en/us/support/docs/unified-communications/business-edition-6000/212062-Procedure-to-Obtain-Licenses-for-Busines.html
==Please rate all useful posts and mark as answer if it solves your issue==
4 REPLIES 4
Highlighted
java
Highlighted
Collaborator
Highlighted
Thank You Nithin..
Highlighted
Hi Abdul,
You also need to consider that Cisco has announced End of life for BE 6000 servers (C220M3) for medium and high density servers.
https://www.cisco.com/c/en/us/products/collateral/unified-communications/business-edition-6000/eos-eol-notice-c51-734081.html
https://www.cisco.com/c/en/us/products/collateral/unified-communications/business-edition-6000/eos-eol-notice-c51-734760.html
Mohammed Rafi
