03-11-2016 11:28 AM - edited 03-17-2019 06:12 AM
Does anyone has solution for Visual Voice mail on 8861 phone? I found this info-
https://bst.cloudapps.cisco.com/bugsearch/bug/%20CSCuq94508
but I am not sure what is this means-' it is required to create additional service and subscribe it to the phone instead of Visual Voicemail service used on other phones.'....what additional service and where? Thanks
Solved! Go to Solution.
03-11-2016 11:48 AM
Have you tried the steps from the administration guide?
03-11-2016 11:48 AM
03-11-2016 01:13 PM
Thanks Jamie...I have been reading different docs out there and trying to understand this issue. My understanding is- there is no way 8861 will work with a service where category is configured as JAVA MIDlet!!! I need to create another phone service 'XML Service' for this model to work!!!! Am I going to right direction?
03-11-2016 01:22 PM
Yes, if you review the regular instructions of VVM, they do tell you to create a Java Midlet option, if you review the link I sent you, it tells you to create it as an XML service.
06-08-2017 02:04 PM
This worked for me:
++select Device-->Device Settings-->Phone Services in Cisco Unified Communications Manager Administration
++select Add New
++enter information in the IP Phone Services Configuration window as follows
-->Service Name: meaningful name, eg.VisualVoicemail-BE
-->Service URL: Application:Cisco/VisualVoiceMail
-->Service Category: XML Service
-->Service Type: Messages
-->Service Vendor: Cisco
-->Enable: yes
++Select Save
++Parameter Name: voicemail_server
++Parameter Display Name: Voicemail Server
++Default value: hostname or IP address of primary CUC server
++Parameter Description: Hostname of voicemail server
++Parameter Name: call_connect_delay
++Parameter Display Name: Call Connect Delay
++Default value: 1000
++Parameter Description: Default Call Connect Display
++Parameter Name: log_level
++Parameter Display Name: Log Level
++Default value: info
++Parameter Description: level of logging
++Select Device-->Phone
++Search for the phone in the Find and List Phone window
++Select the phone
++Select Subscriber/Unsubscribe Services from Related Links, then select Go
++Select the Visual Voicemail service from the Select a Service dialog box
++Select Next
++Select Subscribe
