1396
karim7784
Beginner
Cisco Call Manager 7.x with Windows Server 2008 R2
Guys greting,
Does the Cisco call manager version 7.x is compatabible to work with windows server 2008 R2 enviroment as i found no docs regarding this issue and I will have a migration to do.thx
2 REPLIES 2
shshami
Beginner
Hello Karim,
What do you want exacty to do with the Windows Server 20008? do you want to install TSP/ RTMT or what exactly?
Thank you,
Shadi
Chris Deren
Hall of Fame Master
If you are asking if CUCM itself can run on Windows 2008, the answer is NO and it never will as Windows based supported ended with CUCM 4.3 on Windows 2003. All CUCM versions since version 5.0 are Linux Appliances.
HTH,
Chris
Create
Recognize Your Peers
Content for Community-Ad
