04-27-2011 02:26 AM - edited 03-16-2019 04:41 AM
Hi NetPro.
Good Day . Appreciate if you could share with me about the Cisco CallManager v3 - v4 licenses are purchase individually ? or come with bundled set ?
IF CM 3 and CM4 is counting on individually what about CM5 and above ?
Your reply will be highly appreciated.
Kitten
04-27-2011 03:03 AM
CM Licensing is really too complicated. I recommend that unless you have an absolute need to know, let the matter rest.
04-27-2011 08:01 PM
Hi Paolo.
Good day, thanks for your information . the reason why i need to know is because my customer using different platform some of the using CCM and some of them using CME . i am doubt so which lic to be quoted .
Kitten
04-28-2011 01:23 AM
If you are a reseller, contact you Distributor or Cisco CAM for help.
If you are not, contact a Cisco reseller.
