394
Highlighted
Beginner
Cisco CCMBE Unity Connection Issues
Hi everybody
Recently i installed a CCMBE version 6.0 but when a user try to consult the voice mail the unity play the Auto Attendant and didn't play the option to  enter the password to login, the user need's to press # and then user and password.
PS: The user has a valid voice mail configured in Unity Conection.
Any ideas to solve the problem?
Thanks.
3 REPLIES 3
Highlighted
Hall of Fame Cisco Employee
Look at the routing rules and make sure the attempt sign in is the 1st one.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Highlighted
The attempt sign is the 1st one so the problem continue
Any other suggestion?
Thanks.
Highlighted
Can you check direct routing rule, is there any entry that matches the Auto Attendant pilot number.
-Atul
Please rate, if this helps
