514
Beginner
Cisco Cius and CUCM 7.1.5 BLF issue
I am running CUCM 7.1.5.32020-1 and recently introduced Cisco Cius tablets in our environment.
On the Cisco Cius, we are running software version: sipcius.9-2-1SEC
The issue I am having is that after I configure 5 different BLF in CUCM and they appear on the Cius, if I press the screen to call one user via the BLF, all the BLF names change to that of the first person.
To make this simpler, let's say I configure 5 different BLF's with the names: John, Jack, Jane, Joe, Jeff, in that order.
After they appear on the Cius and I were to call Jane, all the names of the BLF's on the Cius change to the name John.  Is this some kind of bug on the Cius or on CUCM?
I hope that makes sense.
2 REPLIES 2
Beginner
Re: Cisco Cius and CUCM 7.1.5 BLF issue
any ideas? Thanks!
Highlighted
Enthusiast
I'm running into the same issue as you.  We just got some demo Cius' and I have one set up with 1 line and 5 BLF's.  For no reason, all 5 BLF's will display the first BLF intermittently.
CUCM 7.1.5.31900-3 with device pak 7.1.5.34091-1
CIUS Active Load - sipcius.9-2-2-49
I do have another CIUS set up with 1 line and 3 BLFS (using the same phone button template), so far, I've NOT been able to make that one go screwy.
Symptoms of probem CIUS:
Upon bootup - all 5 BLF's show top line
Ramdomly, they will switch to display properly
No matter what the button displays, it calls the correct number when pressed
When I pick up one of the lines, ALL 5 BLFs light up red (hope this is not too confusing)
Anyway, I'm going to call TAC to see if they have a fix or if it's just a "Feature" of CUCM 7.1.5 and Cius'
Pete
Content for Community-Ad
August's Community Spotlight Awards
