10-07-2011 01:30 AM - edited 03-16-2019 07:22 AM
i am playing around with the Cisco CIUS. I sometimes see a question mark in the battery symbol (instead of the green battery) and when this happens the clock next beside the battery symbol stops. I have rebootet the CIUS, took it out of the media station, no effect. Also when the question mark appears the WLAN symbol or the Ethernet-symbol disappears. Anyone seen this before? Why is that?
10-07-2011 03:19 AM
I have not seen that before, could you attach a problem report?
11-04-2011 06:04 AM
Hitting Bug CSCtt19945
03-20-2012 02:49 AM
Interestingly this has been fixed in 9.2.2 but reappeared in 9.2.3
I've just upgraded my three beloved cius wifi. Factory reset, provisioning via CUCM including german locale, reboot: question mark returned instead of battery.
Sebastian
11-21-2013 09:41 AM
I am trying to connect a Cius to a non cisco SIP server.
Therefor I would need a working SEPxxx.cnf.xml file.
I already have perfectly working config files for the 9900 and 7900 series,
but the cnf.xml for the Cius seems to be completly different.
The only thing i was able to manage, was to upgrade the firmware to 9-2-4-45.
Can anyone provide me an example cnf.xml for the cius?
The two most important things would be the locale and the line config part.
I don't have a CallManager to automatically generate the files.
05-27-2017 10:50 AM
Hello have you do it?
