Trying to get cme working in home lab. After many attemps to get it working on my own, I basically copied the Cisco example and tweaked it.
Internal dialing extension to extension works. (have since made both phones same extension)
Dialing "9" for outside, get fast busy after a delay.
Incoming works when calling from my cell phone.
CME-Router#sho sip-ua register status
Line peer expires(sec) registered
904xxxxxxx -1 17 yes
CME-Router#
CME-Router#sho ephone registered
ephone-1 Mac:001B.D4C6.975D TCP socket:[1] activeLine:0 REGISTERED in SCCP ver 9 and Server in ver 8
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:8
IP:172.22.100.3 50414 Telecaster 7960 keepalive 235 max_line 6
button 1: dn 11 number 201 CH1 IDLE CH2 IDLE shared
ephone-2 Mac:001B.53C6.39C7 TCP socket:[3] activeLine:0 REGISTERED in SCCP ver 9 and Server in ver 8
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:9
IP:172.22.100.2 51530 7906 keepalive 141 max_line 2 dual-line
CME-Router#
Attached config and other info. Let me know what else I need to provide in the form of debug commands etc..
Thanks in advance
Message was edited by: TONY JOHNSON
