Cisco CME 8.0 SCCP phone can't call SIP phone registered with Voice Register Global
Thai Huynh
Hi everyone,
I'm new with CME and I'm have a problem to make a call from SCCP to SIP phone, SIP phone registered fine under Voice Register Global, I can make the call from SIP to SCCP and working perfectly, example: SIP(ext 2001) dial 1002 ---> SCCP(1002) work fine, SCCP(ext 1002) dial 2001 ---> SIP(ext 2001) not working, below is my config and debug output, please help as I have tried to sovel this problem for a last few days ..without luck
I have modified the config to make it shorter.
I made a call from ext 1002 to ext 2001 and debuged.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
no fax-relay sg3-to-g3
h323
modem passthrough nse codec g711ulaw
sip
  registrar server expires max 250 min 200
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice register global
mode cme
source-address 192.168.1.1 port 5060
max-dn 20
max-pool 10
authenticate register
voicemail 5003
tftp-path flash:
file text
create profile sync 001902402159062A
voice register dn  1
number 2001
allow watch
mwi
voice register dn  2
number 2002
allow watch
mwi
voice register pool  1
id mac 08GF.45NH.33BG
number 1 dn 1
template 1
presence call-list
dtmf-relay sip-notify
username 2001 password test1
codec g711ulaw
voice register pool  2
id mac DF34.98KJ.FGH1
number 1 dn 2
presence call-list
dtmf-relay rtp-nte
username 2002 password test2
codec g711ulaw
dial-peer voice 13 voip
translation-profile outgoing PSTN_OUTGOING
destination-pattern 9[0-1][2-9]........
session protocol sipv2
session target sip-server
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 11 voip
destination-pattern 9001T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 12 voip
destination-pattern 9[2-9].......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 21 pots
service aa
incoming called-number .
direct-inward-dial
port 0/3/0
dial-peer voice 100 voip
service aa
destination-pattern 123456789
incoming called-number 123456789
dtmf-relay rtp-nte
codec g711ulaw
no vad
interface Loopback0
ip address 100.100.100.100 255.255.255.0
interface FastEthernet0/0
ip address 172.16.3.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip nat inside
duplex auto
speed auto
Interface vlan 1
ip address 10.0.0.1 255.255.255.0
ip nat inside
telephony-service
em logout 0:0 0:0 0:0
max-ephones 20
max-dn 50
ip source-address 10.0.0.1 port 2000
max-conferences 8 gain -6
moh en_bacd_music_on_hold.au
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  2  dual-line
number 1002
ephone  2
device-security-mode none
mac-address 1234.339C.4321
button  1:2
DEBUG OUTPUT:
The Call Setup Information is:
Call Control Block (CCB) : 0x4A6F46F0
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 1002
Called Number            : 2001
Source IP Address (Sig  ): 124.184.95.113
Destn SIP Req Addr:Port  : 203.161.160.71:5060
Destn SIP Resp Addr:Port : 203.161.160.71:5060
Destination Name         : trunk.engin.com.au
*Oct  9 17:17:53.509: //4319/178076CE8755/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 124.184.95.113
Source IP Port    (Media): 19548
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
*Oct  9 17:17:53.509: //4319/178076CE8755/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 1
Disconnect Cause (SIP)   : 604
DEBUG OUTPUT:
Router#
*Oct  9 17:21:15.261: //4348/8FD13E9C8769/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
*Oct  9 17:21:15.269: //4348/8FD13E9C8769/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 124.184.95.113
*Oct  9 17:21:15.269: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 18630 for stream 1
*Oct  9 17:21:15.273: //4348/8FD13E9C8769/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
*Oct  9 17:21:15.273: //4348/8FD13E9C8769/SIP/Media/sipSPIProcessRtpSessions: No active streams.
*Oct  9 17:21:15.273: //4348/8FD13E9C8769/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 4348) to the VOIP RTP library
*Oct  9 17:21:15.273: //4348/8FD13E9C8769/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 124.184.95.113
*Oct  9 17:21:15.277: //4348/8FD13E9C8769/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Oct  9 17:21:15.277: //4348/8FD13E9C8769/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 124.184.95.113, lport = 18630, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
        src_callid = 4348, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
        media_ip_addr =  - , vrf tableid = 0 media_addr_type = 1
*Oct  9 17:21:15.277: //4348/8FD13E9C8769/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
*Oct  9 17:21:15.277: //4348/8FD13E9C8769/SIP/Media/sipSPICreateRtpSession: stun is disabled
*Oct  9 17:21:15.345: //4348/8FD13E9C8769/SIP/Media/sipSPIDestroyRtpSession: stream:4AB72544
DEBUG OUTPUT:
Router#debug ccsip messages
SIP Call messages tracing is enabled
Router#
*Oct  9 17:28:53.909: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:2001@192.168.1.2:5060 SIP/2.0
Via: SIP/2.0/UDP 124.184.95.113:5060;branch=z9hG4bKA890
From: <sip:1002@trunk.engin.com.au>;tag=27EF894-76E
To: <sip:2001@192.168.1.2>
Date: Tue, 09 Oct 2012 17:28:53 GMT
Call-ID: A1D7FDE3-116D11E2-8795CE13-5722CA25@124.184.95.113
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2704086970-0292360674-2274414099-1461897765
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1349803733
Contact: <sip:1002@124.184.95.113:5060>
Call-Info: <sip:124.184.95.113:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 270
v=0
o=CiscoSystemsSIP-GW-UserAgent 8919 3652 IN IP4 124.184.95.113
s=SIP Call
c=IN IP4 124.184.95.113
t=0 0
m=audio 18106 RTP/AVP 0 100 19
a=rtpmap:0 PCMU/8000
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:19 CN/8000
a=ptime:20
*Oct  9 17:28:53.953: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
*Oct  9 17:28:53.969: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 604 Does not exist anywhere
To: <sip:2001@192.168.1.2>;tag=SD0s3fa99-1560815025-1349800544451
CSeq: 101 INVITE
Content-Length: 0
*Oct  9 17:28:53.981: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:2001@192.168.1.2:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Call-Info: <urn:x-cisco-remotecc:callinfo>; security= unknown
Content-Length: 0
paolo bevilacqua
To: <2001>;tag=SD0s3fa99-1560815025-1349800544451
Check that your phone is configured to be 2001.
paolo bevilacqua
Thanks Paolo, also thanks for all other posts you posted. Thanks
Thank you for the nice rating and good luck!
