Cisco CME and Avaya Office inter call routing
syed kazim abbas
Participant
Participant
Hello experts,
we have CME 10.0 running cisco phones and the other site have Avaya office and server running Avaya phones , how can I route call between them.
Best Regards,
Kazim Abbas
Adarsh Chauhan
Participant
Participant
You will have to get some kind of IP connectivity between two site and then make a dial-peer on CME pointing to the IP of the Avaya Server.
Example.
dial-peer voice 1 voip
destination-pattern <avaya extension generic pattern>
session protocol sipv2
session target ipv4:<IP of the Avaya server>
dtmf-relay rtp-nte sip-notify <DTMF capabilities>
voice-class codec 1
Please rate and mark correct if helpful
Adarsh Chauhan
Adarsh Chauhan
Hi Adarsh,
thanks for your help. I tried the above as you mentioned but connection refused by avaya. I am using codec G711alaw. but ip reach-ability end to end is ok.
regards,
Kazim Abbas
