Community Helping Community
102
Beginner
Cisco CME and Panasonic PABX integration
I have a client who is running a Panasonic Pabx Telephony. Now i would like to implement Cisco IP Phones but i want to start like 50% of users at the site will be on Cisco IP Phones and other 50% will keep using Panasonic for now.
So question is how to make them work together so they can communicate each other on intercom and also to make outgoing calls.
Nooruddin
1 ACCEPTED SOLUTION
Hall of Fame Cisco Employee
I don't think intercom would
I don't think intercom would work across this solution, the CME intercom feature works with the phones registered to it.
It would be simply to configure your integration between the boxes, you don't even mention which side would be managing the outgoing calls, but simply configure the DPs or whatever is the equivalent on the PABX to route calls to the other system with any digit manipulation that might be required
java
if this helps, please rate
1 REPLY 1
java
Content for Community-Ad
FusionCharts will render here
