cisco CME billing
sarenos2006
Beginner
Beginner
I have to install a CCME in a hotel and my problem is how to do the billing per room and then charge it to the final invoice in the check out.
Is there any billing solution for integrating it in CCME?
Which solution do you recommend?
5 REPLIES 5
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
One official cisco partner that does this is called stonevoice, there are others as well.
Rob Huffman
Hall of Fame Community Legend Hall of Fame Community Legend
Hi Santi,
Paolo has hit the nail on the head here (no surprise), I just thought I would add the link for you :)
http://www.stonevoice.com/Products/AccountingBilling/tabid/767/Default.aspx#o
Hope this helps!
Rob
iptuser55
Frequent Contributor
You may want to see a company called Tiger
http://www.tigercomms.com/english/
They have Call logging for both business and Hotels with client check out, clean rooms etc features
Yes in fact an hotel pbx is different in many way from a company one, so for both the configuration and billing you may want to take a specialized approach,
jirka.novak
Beginner
Beginner
Try TAS from http://www.2ring.com, it has module for hotel environment.
