04-26-2018 02:18 AM - edited 03-18-2019 12:24 PM
I have Cisco CME 11.5
Scenario:
Any suggestions on this?
SIP -> CME 11.5 -> Phone A (6945) -> Phone B (6945)
Thanks in advance,
Kamil
Solved! Go to Solution.
04-27-2018 08:20 AM
04-26-2018 04:43 AM
My config:
! ip dhcp pool VOICE network 192.168.0.0 255.255.255.0 default-router 192.168.0.1 option 150 ip 192.168.0.1 ! ! ! ! ! voice-card 0 ! ! ! voice service voip ip address trusted list ipv4 xx.xx.xx.xx allow-connections h323 to h323 allow-connections h323 to sip allow-connections sip to h323 allow-connections sip to sip fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none sip early-offer forced midcall-signaling passthru ! ! ! ! ! ! voice translation-rule 1 rule 1 /^.*/ /222/ ! ! voice translation-profile IN translate called 1 ! ! ! ! application service aa flash:its-CISCO.2.0.3.0.tcl paramspace english index 0 paramspace english language en param operator 101 paramspace english location flash: paramspace english prefix en param aa-pilot 222 ! ! hw-module pvdm 0/0 ! hw-module pvdm 0/1 ! ! ! ! redundancy ! ! ! ! ! ! interface Embedded-Service-Engine0/0 no ip address shutdown ! interface GigabitEthernet0/0 ip address dhcp ip nat outside ip virtual-reassembly in duplex auto speed auto ! interface GigabitEthernet0/1 ip address 192.168.0.1 255.255.255.0 ip nat inside ip virtual-reassembly in duplex auto speed auto ! interface GigabitEthernet0/2 no ip address shutdown duplex auto speed auto ! ip forward-protocol nd ! no ip http server no ip http secure-server ! ip nat inside source list 100 interface GigabitEthernet0/0 overload ! ! access-list 100 permit ip 192.168.0.0 0.0.0.255 any ! ! ! ! dial-peer voice 222 voip service aa destination-pattern 222 progress_ind setup enable 3 progress_ind progress enable 8 session target ipv4:192.168.0.1 incoming called-number 222 dtmf-relay h245-alphanumeric codec g711ulaw no vad ! dial-peer voice 199 voip destination-pattern 6........ session protocol sipv2 session target dns:sip.xxx.pl dtmf-relay rtp-nte codec g711ulaw no vad ! dial-peer voice 198 voip translation-profile incoming IN session protocol sipv2 session target dns:sip.xxx.pl incoming called-number .% dtmf-relay rtp-nte codec g711alaw no vad ! ! sip-ua credentials username xxx password 7 0fewfewfewfewfew8 realm dns:sip.xxx.pl authentication username xxx password 7 ffewfewfewfewfew registrar dns:sip.xxx.pl expires 900 auth-realm xxx sip-server dns:sip.xxx.pl ! ! ! telephony-service max-ephones 10 max-dn 10 ip source-address 192.168.0.1 port 2000 cnf-file location flash: cnf-file perphone max-conferences 8 gain -6 moh enable-g711 "en_bacd_music_on_hold.au" transfer-system full-consult transfer-pattern .T create cnf-files version-stamp Jan 01 2002 00:00:00 ! ! ephone-dn 1 dual-line number 101 ! ! ephone-dn 2 dual-line number 102 ! ! ephone-dn 3 dual-line number 103 ! ! ! ephone 1 mac-address C414.3C8B.A5EA type 6945 button 1:3 ! ! ! ephone 3 mac-address 0C27.24BB.E554 type 6945 button 1:1 ! ! ! ephone 4 mac-address 0C27.24BA.D598 type 6945 button 1:2 !
04-26-2018 07:42 AM
04-27-2018 12:20 AM
Thanks for reply...
full-blind - call disconnected after transfer
full-consult dss - call transfered but no ringtone for caller
Best regards,
Kamil
04-27-2018 12:49 AM
04-27-2018 01:58 AM
Yes, transfer is completed and there is no ring back while Phone B is ringing.
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.6(3)M, RELEASE SOFTWARE (fc1)
04-27-2018 08:20 AM
04-29-2018 01:54 PM
Thanks. I will try upgrade in Wed and reply soon.
Best regards,
Kamil
05-02-2018 04:12 AM
