[Cisco CME] no ringback when call transfer
kamil_folga
I have Cisco CME 11.5
Scenario:
  1. External caller (from SIP TRUNK) calls phone A. Ringback is OK.
  2. Then the call is transfered (full-consult) to phone B
  3. Phone B is ringing but the external caller is not hearing a ringback tone.
Any suggestions on this?
 SIP -> CME 11.5 -> Phone A (6945) -> Phone B (6945)
  Thanks in advance,
Kamil
Yup. I suspected that. You are running into the following -
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvb00288/?reffering_site=dumpcr
Upgrade and that should fix the issue. Don't worry about it saying blind transfer. Your situation applies as well.
8 Replies 8
kamil_folga
My config:
ip dhcp pool VOICE
 network 192.168.0.0 255.255.255.0
 default-router 192.168.0.1
 option 150 ip 192.168.0.1
voice-card 0
voice service voip
 ip address trusted list
  ipv4 xx.xx.xx.xx
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  early-offer forced
  midcall-signaling passthru
voice translation-rule 1
 rule 1 /^.*/ /222/
voice translation-profile IN
translate called 1
application
 service aa flash:its-CISCO.2.0.3.0.tcl
  paramspace english index 0
  paramspace english language en
  param operator 101
  paramspace english location flash:
  paramspace english prefix en
  param aa-pilot 222
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface GigabitEthernet0/0 overload
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
dial-peer voice 222 voip
 service aa
 destination-pattern 222
 progress_ind setup enable 3
 progress_ind progress enable 8
 session target ipv4:192.168.0.1
 incoming called-number 222
 dtmf-relay h245-alphanumeric
 codec g711ulaw
 no vad
dial-peer voice 199 voip
 destination-pattern 6........
 session protocol sipv2
 session target dns:sip.xxx.pl
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 198 voip
 translation-profile incoming IN
 incoming called-number .%
 dtmf-relay rtp-nte
 codec g711alaw
 no vad
sip-ua
 credentials username xxx password 7 0fewfewfewfewfew8 realm dns:sip.xxx.pl
 authentication username xxx password 7 ffewfewfewfewfew
 registrar dns:sip.xxx.pl expires 900 auth-realm xxx
 sip-server dns:sip.xxx.pl
telephony-service
 max-ephones 10
 max-dn 10
 ip source-address 192.168.0.1 port 2000
 cnf-file location flash:
 cnf-file perphone
 max-conferences 8 gain -6
 moh enable-g711 "en_bacd_music_on_hold.au"
 transfer-system full-consult
 transfer-pattern .T
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
 number 101
ephone-dn  2  dual-line
 number 102
ephone-dn  3  dual-line
 number 103
ephone  1
 mac-address C414.3C8B.A5EA
 type 6945
 button  1:3
ephone  3
 mac-address 0C27.24BB.E554
 type 6945
 button  1:1
ephone  4
 mac-address 0C27.24BA.D598
 type 6945
 button  1:2
R0g22
What is the behavior with blind or semi-consult ?
Thanks for reply...
full-blind - call disconnected after transfer
full-consult dss - call transfered but no ringtone for caller
Best regards,
Kamil
So you are doing a semi-consult ? By that I mean, Phone A receives a call, does a transfer to Phone B but has not answered. The transfer is completed and there is no ring back while Phone B is ringing ? Can you confirm this please ?
Also, what is the IOS ?
Yes, transfer is completed and there is no ring back while Phone B is ringing.
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.6(3)M, RELEASE SOFTWARE (fc1)
Thanks. I will try upgrade in Wed and reply soon.
Best regards,
Kamil
Thanks :) It`s works :)
