04-07-2011 09:55 AM - edited 03-16-2019 04:24 AM
Hello all,
Our company has CME v7.1 running on a 3845. Our phones are mostly 7906 and 7911. I live in Angola, a country with GMT+1 time. We dont have Daylight Savings Time and our time is constant the whole year. Time is displayed correctly except it changes along the year.
The list of time under telephony service only have +60(min) time zone with Daylight time (check below)
Is there anyway to remove the DST just like "clock set" on exec mode?
Thanks very much
rw-ld-sede-01(config-telephony)#time-zone ?
<1-53> select timezone name used by IP phones (offset in minutes)
1 Dateline Standard Time -720
18 SA Eastern Standard Time -180
19 Mid-Atlantic Standard/Daylight Time -120
20 Azores Standard/Daylight Time -60
21 GMT Standard/Daylight Time +0
22 Greenwich Standard Time +0
23 W. Europe Standard/Daylight Time +60
24 GTB Standard/Daylight Time +60
25 Egypt Standard/Daylight Time +60
26 E. Europe Standard/Daylight Time +60
27 Romance Standard/Daylight Time +120
Solved! Go to Solution.
04-07-2011 09:44 PM
If there is no correct TZ, you will have to manually change time twice a year.
04-07-2011 09:44 PM
04-07-2011 11:33 PM
Paolo,
Thanks for your time.
Really? I have seen information talking about "locale" installation for different languages. Is there no way to install new time-zones?
04-07-2011 11:52 PM
As mentioned before:
There is NO way.
Please remember to rate useful posts clicking on the stars below.
04-08-2011 06:52 AM
Thanks Paolo,
I'll just have to keep changin then. Anywhere I can make feature requests to CISCO?
04-11-2011 10:37 AM
netone.cisco wrote:
Thanks Paolo,
You could, but it's mostly wasted time.
Thanks for the nice rating, and good luck!
04-15-2013 03:16 AM
Quick question from a newbie : I'm facing the same issue, so how do you manually change the time on CME ?
