04-06-2015 02:46 PM - edited 03-17-2019 02:33 AM
I've been asked to provide a report of calls to and from an extension from a cisco desk phone. This report does not need to be elaborate. Date, Time and caller ID is sufficient. I'm unable to find in the UCM where I can accomplish this. Any assistance would be appreciated. TIA
04-06-2015 03:32 PM
You can use CDR/CAR for that, plenty of threads on the topic on CSC
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/9_1_1/cdrdef/CUCM_BK_C268EF1B_00_cucm-cdr-admin-guide-91.html
04-07-2015 07:02 AM
I guess I didn't clarify what I meant by 'simple'.
04-07-2015 07:18 AM
That is as simple as it gets with the CUCM.... Not sure what else you are looking for here. You go into the CDR page, put the extension you want to view and the range of dates and hit submit then it provides a graph of time, date, and called/calling number. Java's answer is the best you are going to get without some third party solution.
04-06-2015 09:09 PM
You may install a Call Log Analysis/Accounting S/W like IPERA Communication Suite.
This way you will be able to have comprehensive / custom reports
