10-20-2020 12:09 PM
We have 3 Cisco 8851-3PCC that have both a side car and usb headset. The Phone System is Free PBX, We are having issues with the phones rebooting pretty often. The 8841 that are configured the same way, do not reboot. Any Ideas?
10-20-2020 02:43 PM
Are the phones running on PoE or power brick?
10-21-2020 02:40 AM
10-21-2020 05:27 AM
Check the power config setting
10-22-2020 01:06 PM
The Phones are configured through the web interface on the phone, it connects using the un and pw provided in the freepbx extension when created. as far as tftp configs or anything like that, they have not been setup. I looked to see if there was any mention of power settings in the phone inside the web access and have not located any.
10-22-2020 02:45 PM
Try updating the firmware of the phone and see what happens?
10-26-2020 02:14 AM
What firmware version are you using?
if you go on the web UI and navigate to Voice --> Att Console, you can find KEM Type. Make sure you have the correct KEM type assigned. Also, you will see on that page "Number of Units" - this is the number of KEMs that you have.
As for the power, you will find it under Voice-->System-->Power Settings-->PoE Power Required.
Hope it helps
Geovani
10-29-2020 08:01 AM
Firmware is SIP88XX.11-3-1MSR3-3
After Adjusting power settings to MAX Power and making sure KEM is set to 1 unit, the phones did not reboot for 2 days, however they have now started up again.
