Cisco CP-8851 Web Browser Combability
Hi there,
I currently have a CP-8851-3PCC and I can not access the Webui at all. If I launch in Chrome, Opera, Firefox, Edge it will just display a loading wheel in the middle of the page. I believe this is because they are based on Chromium.
If I load in IE it will let me log in but wont let me access any settings accept the User Tab under voice and the Info tab. On all the other tab it just displays the same loading icon.
What web browser can I use
Thanks in advance
Kind Regards
Reece
Info of the phone below:
Product Name: CP-8851-3PCC
Software Version: sip88xx.11-1-1MPP-897.loads
Hardware Version: V01
Geovani
You might have an issue with chrome, when using that fw version, its pretty old.
Try to access using IE, logging directly to the admin advanced page: http://IP_Address/admin/advanced
Once you upgrade to a later firmware, you won't have this issue anymore and you'll be able to use Chrome, Firefox, Edge etc..
I have tried this but when trying to access the provisioning menu in order to put the upgrade rule I am presented with this screen, no matter how long you leave it it will keep on spinning.
Reece
Geovani
This is strange, that shouldn't happen.
Can you please try upgrading using the browser URL?
Please see page 102 of the admin guide
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/MPP/8800/english/AG/p881_b_8800-mpp-ag_new.pdf
You should use something like:  http://<phone_ip>/admin/upgrade?http://<serv_ip[:port]>/upgradefile.loads
Failing that, try performing a factory reset (if not already tried it)
Geovani
