Cisco Cube - Sip Statistics and show logging
J_Cormier
I'm trying to understand our logs from Cisco Cube and I cannot find documentation for those error. I dont know if that can cause issue. Any reference document exist ? I've more details with show logging but not enough to find any explanation.
Thank you
SIP Global Counters:
<File Id, Line: Count First Occurence Most Recent Occurence
Message>
0x7 , 2854 : 1856 Apr 21 2021 15:19:52 Apr 28 2021 14:53:29
Corrupted/Freed Container=%p
0x9 , 2134 : 1 Apr 23 2021 13:02:09 Apr 23 2021 13:02:09
Error in matching To header tags
0x9 , 5329 : 1856 Apr 21 2021 15:19:52 Apr 28 2021 14:53:29
next_choice == %d
0xC , 227 : 204523 Apr 21 2021 15:17:04 Apr 28 2021 14:59:01
Freeing NULL pointer!
0xD , 1813 : 33686 Apr 21 2021 15:17:17 Apr 28 2021 14:58:58
Unknown Call-Info Header
0x17 , 1712 : 1 Apr 22 2021 10:31:33 Apr 22 2021 10:31:33
handle cached event after ACK for incoming INVITE
0x17 , 2434 : 21 Apr 21 2021 15:18:43 Apr 28 2021 13:40:43
No To header information available
0x17 , 9860 : 22 Apr 21 2021 18:55:43 Apr 27 2021 16:04:40
Unexpected response
0x17 , 11391 : 2 Apr 23 2021 11:37:26 Apr 26 2021 08:34:51
Unexpected ACK
0x17 , 14307 : 1 Apr 23 2021 16:12:39 Apr 23 2021 16:12:39
Out of retries
0x17 , 14610 : 1 Apr 23 2021 16:45:41 Apr 23 2021 16:45:41
Out of retries
0x17 , 15506 : 3 Apr 26 2021 11:02:01 Apr 28 2021 12:39:52
Failure in media negotiation -- Sending %d response
0x17 , 16090 : 1 Apr 22 2021 10:31:33 Apr 22 2021 10:31:33
REQUEST_OFFER is cached until incoming UPD/INV is done
0x17 , 20155 : 78 Apr 21 2021 15:53:24 Apr 28 2021 13:42:57
Don't expect a callerid update in %s
0x17 , 20469 : 14 Apr 23 2021 16:45:41 Apr 27 2021 19:10:40
Invalid method for (STATE_IDLE): %s
0x21 , 733 : 2 Apr 22 2021 10:14:26 Apr 28 2021 10:37:36
Unknown PSTN cause code from CCAPI:%d
0x21 , 2729 : 233554 Apr 21 2021 15:17:04 Apr 28 2021 14:59:01
Invalid deferredQueue
0x21 , 3078 : 5 Apr 22 2021 10:54:38 Apr 28 2021 14:11:09
invalid ccb, bName or branch list for sipSPIRemoveBranchName
0x21 , 4532 : 1858 Apr 21 2021 15:19:52 Apr 28 2021 14:53:29
No Inbound Container Created !!!
0x21 , 4570 : 1858 Apr 21 2021 15:19:52 Apr 28 2021 14:53:29
0x24 , 605 : 64294 Apr 21 2021 15:17:07 Apr 28 2021 14:58:59
Invalid parameters
0x27 , 8310 : 33042 Apr 21 2021 15:17:07 Apr 28 2021 14:58:59
ReqLine IP addr does not match with host IP addr ***JCO:Missing DNS entry for cuspa.capitale.qc.ca et cuspb.capitale.qc.ca***
0x27 , 10742 : 9277 Apr 21 2021 15:19:27 Apr 28 2021 14:54:08
Failed to get elem value from INFO Queue
0x28 , 5175 : 39841 Apr 21 2021 15:17:07 Apr 28 2021 14:58:59
No session target configured
0x30 , 13753 : 1 Apr 23 2021 16:12:39 Apr 23 2021 16:12:39
Not SIP2SIP mode
0x31 , 353 : 13 Apr 21 2021 17:12:22 Apr 27 2021 19:10:40
MF: failed to send CC_EV_H245_MEDIA_FORKING_START_IND
0x31 , 2322 : 138542 Apr 21 2021 15:17:04 Apr 28 2021 14:59:01
MF: Dial-peer is absent..
0x31 , 2428 : 138542 Apr 21 2021 15:17:04 Apr 28 2021 14:59:01
MF:video profile Dial-peer is absent..
0x35 , 7696 : 2 Apr 23 2021 16:12:39 Apr 23 2021 16:12:39
Container is NULL
0x35 , 13911 : 26360 Apr 21 2021 15:17:06 Apr 28 2021 14:58:46
Unable to find proper instance for FMTP
0x35 , 13917 : 26360 Apr 21 2021 15:17:06 Apr 28 2021 14:58:46
Unable to acquire event mask for rfc2833
0x37 , 3792 : 78986 Apr 21 2021 15:17:07 Apr 28 2021 14:58:59
CCSIP: invalid call entry
0x3D , 520 : 3 Apr 22 2021 10:14:26 Apr 28 2021 10:37:36
Dead CCB
0x41 , 16850 : 35826 Apr 21 2021 15:17:19 Apr 28 2021 14:58:58
Could not modify QoS params for midcall INVITE
0x41 , 20171 : 13 Apr 23 2021 09:19:15 Apr 28 2021 14:34:06
Pointers are NULL..
0x41 , 20286 : 13 Apr 23 2021 09:19:15 Apr 28 2021 14:34:06
CCB SDP source pointer NULL
0x41 , 21533 : 160 Apr 21 2021 15:23:42 Apr 28 2021 14:46:32
voip_rtp_update_callinfo returns FALSE
0x45 , 1185 : 24 Apr 21 2021 15:32:20 Apr 28 2021 12:57:52
Invalid state/ccb for Notify response for Refer
0x45 , 1197 : 317 Apr 21 2021 15:23:24 Apr 28 2021 14:46:32
0x47 , 1599 : 13 Apr 21 2021 17:12:22 Apr 27 2021 19:10:40
Unable to send ACK sent peer event
0x50 , 1526 : 2202 Apr 21 2021 15:17:17 Apr 28 2021 14:58:22
NULL sdp
0x5A , 7671 : 1 Apr 23 2021 16:12:39 Apr 23 2021 16:12:39
local or remote uuid null
0x5A , 24159 : 1903 Apr 21 2021 15:19:52 Apr 28 2021 14:53:29
Peer CCB is NULL
0x5A , 29379 : 138542 Apr 21 2021 15:17:04 Apr 28 2021 14:59:01
input arg error
0x5A , 29461 : 138542 Apr 21 2021 15:17:04 Apr 28 2021 14:59:01
input argument error
0 Replies 0
