02-04-2013 06:19 AM - edited 03-16-2019 03:31 PM
I have deployed CUBE on a 2921 running IOS 15.3(1)T to link a CUCM 8.6 cluster to an ITSP (Gamma Telecom in the UK).
The ITSP sends/receives calls using G711alaw. This is fine for standard voice calls to IP phones (7940 and 7960) as they support this codec.
The customer also has UCCX 8.5 and this is where the issues are happening. My understanding (correct me if I am wrong!) is that UCCX only supports G711ulaw.
When I try calling a UCCX trigger number via the SIP trunk I get a number unallocated in the CDR record. This implies to me that it is a codec issue and that I need to do some transcoding. It looks like the new CUBE 9.0 Local Transcoding Interface (LTI) feature should solve the problem.
This is detailed in the link below but a full config is not included.
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_tech_note09186a0080bdfd58.shtml
I have tried configuring it but had limited success in the outage period I had available. The calls did not invoke the transcoding functionality and G711alaw was used for both legs whereas I wanted G711alaw for the external leg and G711ulaw for the internal leg. I think the issue may be to do with dial peer matching and will test this later today.
In the meantime I would like to check a few things.
What CUBE version is included with IOS 15.3(1)T on the ISR 2921? - I cannot find an up to date table that maps CUBE versions to IOS.
Has anyone else successfully configured the Local Transcoding Interface on an ISR G2 platform? - if yes can you share your config.
If LTI is not going to work has anyone had any success using the older SCCP/CME based transcoding?
Thanks in advance!
Solved! Go to Solution.
02-04-2013 07:39 AM
James,
First of all unallocated number is definitely not capabilites related. Unless you are looking at the wrong CDR record. Capabilites issues such as codec mismatch always come with cause code of either 47 or 65..which is either resourve unavailable or bearer cap not supported etc..
Second, if you are running IOS 15.2.3T you can definitely use the LTI interface. Below are the steps to configure this
1. Enable dspfarm services
voice-card 0
dspfarm
dsp services dspfarm
2. dsfarm pfrofile configuration
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729abr8
codec g729ar8
codec ilbc
maximum sessions 100
associate application CUBE
3.Bring the Service-Engine
interface up
interface Service-Engine0/1/0
no shut
Thirdly you can use local transocding available on CUBE with sccp to do this also.
Use the steps below..
1. Enable dspfarm services under voice-card
voice-card 0
dspfarm
2. Configure telephony service
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 128
sdspfarm tag 1 CUBE-XCODE
max-ephones 10
max-dn 10
ip source-address
3.sccp configuration
sccp local GigabitEthernet0/0
sccp ccm
identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
4.dspfarm profile configuration
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 10
associate application SCCP
associate profile 1 register CUBE-XCODE
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
02-04-2013 06:30 AM
If your getting unallocated number in the cdr records the problem could also be related to call routing . Could you include
the follwoing from the cube...
-show run
-show ver
-debug ccsip messages
-debug voip ccapi inout
collect the debugs in a logging buffer and also mention your calling and called number used.
Karthik
02-04-2013 06:42 AM
Hi Karthik,
Thank you for the response. I am pretty certain that the issue is not to do with call routing as I can dial DNs assigned to phones in the same partition as the UCCX trigger. The only variable seems to be the codecs supported by the device I am dialling. I will check the call routing again though - I should have permission to do some testing in about four hours and can collect debugs etc. then.
In the meantime I was hoping to get feedback about the CUBE based transcoding feature - has anyone used this yet?
James
02-04-2013 07:39 AM
James,
voice-card 0
dspfarm
codec g711ulaw
codec g711alaw
codec g729abr8
codec g729ar8
codec ilbc
interface up
no shut
voice-card 0
dspfarm
telephony-service
sdspfarm units 1
max-ephones 10
max-dn 10
ip source-address
sccp ccm
sccp
sccp ccm group 1
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 10
02-04-2013 08:32 AM
Thank you for the response. I appreciate it
In the document for configuring LTI that I found there is no mention of bringing the service engine up. The router does not have a Service-Engine0/1/0 but it does have an interface Embedded-Service-Engine0/0 so I guess I can try enabling that.
I will check through the CDRs in more detail too - I was just looking at the call list using the Translator-X tool.
Hopefully I should be able to update this in a couple of hours.
02-04-2013 09:01 AM
Why dont you just look at the sip traces in Translator x and see what the disconnect code is..You may well have a call routing issue..You can send the trace here and we can have a look
02-04-2013 03:29 PM
I have managed to get it working
There were two issues.
The first was the transcoding issue which I solved using the Local Transcoding Interface feature. I did not have to enter
the interface Service-Engine0/1/0 no shut command.
The second issue was call routing related. Basically the trunk could reach the DN assigned to the UCCX trigger but could not reach the DNs assigned to the CTI ports used by UCCX. I solved this by setting the Calling Search Space for Redirect on the UCCX trigger to Route Point Address Search Space.
Many thanks to both guys who responded and Jonathan Schulenberg whose response to a previous thread pointed me in the right direction to resolve the UCCX issue.
02-04-2013 03:34 PM
James,
Glad to hear its resolved. It may be good to mark the thread as answered to help others...
06-16-2015 04:43 AM
I have situation with outbound call. I have raised a TAC case for this
My call routing design is based on G729 end to end as its centralized SIP trunk and remote sites reach to HQ CUBE to send out and receive PSTN calls. Hence all of my region settings are G729
Almost all calls work with g729 except for few long distance calls where AT&T accepts only G711
TAC says CUBE is sending out SIP invite with g729r8 based on the codec sent by the CUCM SIP invite to CUBE. Though My CUBE has voice class codec with
1st preference as G729
2nd preference as g711alaw
3rd preference as g711ulaw
i cant map those individual numbers with separate dial peer hard coded with g711 codec at dial peer level as those numbers may grow in future
TAC suggested to do LTI and that will take care of transcoding, before even i want to configure that. I would like to understand the voice class codec and the CUCM Invite that send g729 codec in invite. Would LTI be invoked incase CUCM sends only G729 codec as per my design? or should I redesign region relation between CUCM and CUBE?
06-16-2015 05:16 AM
Pasting the TAC response here
!!!! This is because the CUBE is doing codec filtering. When CUBE receives the G729 codec from cucm it will filter the outgoing codecs to provider as per incoming offer. This means that since cucm sends g729 , CUBE will not be able to send all offered codecs including g711 as it sees the limited bitrate coming from the CUCM. So even if voice class codec has all codecs it will still send g729. So we need CUBE application’s intelligence that if a transcoder is registered locally to it, it will be able to handle a G729-G711 call. this way CUBE will be able to send G711 in outgoing direction.
Hope this makes sense. !!!!
So in my case CUBE is offering only G729 and AT&T immediately sends Bearer Not capable and disconnects the call.. after configuring Transcoder will outbound call codec offer will change?
