08-01-2018 11:53 AM - edited 03-18-2019 12:28 PM
How to list up Cisco CUCM 11.5 Busy Lamp Field/Speed Dial Buttons. I need a report of what Busy Lamp Field/Speed Dial Buttons are on each phone in the system.
Solved! Go to Solution.
08-01-2018 12:26 PM
There is no native report for that, you'd need to use a bat export all and then filter the report to get that info.
08-01-2018 12:26 PM
